How to uninstall Fusion 360 manually
I want to uninstall and reinstall the Fusion 360 from my MacBook Pro due to some issues however, I can't use 'Remove Autodesk Fusion 360' icon at Launch Pad.. coz it was accidentally removed by me. So please let me know how to uninstall Fusion 360 manually.
Thanks.
JJ
Phil.E
@Anonymous
Hi welcome to the Fusion forums.
The manual uninstall instructions are listed on the readme page.
https://forums.autodesk.com/t5/design-validate-document/fusion-360-readme/td-p/4311780
The instructions are pasted below for Windows and Mac.
Phil
Uninstalling Older Builds
  • When using Fusion 360 there are files created that may not be deleted during the uninstall process. To completely remove Fusion from your computer, the following steps can be used:
   WINDOWS
    Uninstalling
         1. Go to the Start Menu > Control Panel > Uninstall Programs.
         2. Select the existing Autodesk Fusion 360  entry from the list
             and click Uninstall.
         3. Upon completion of the uninstall program exit Control Panel.
     Clearing remaining program files:
          1. Launch Windows Explorer.
          2. Navigate to: C:\Users\<username>\AppData\Local\Autodesk
          3. Delete the following folders (if present):
              - Autodesk Fusion 360
              - Web Services
              - Webdeploy
              - production
              - Neutron Platform
              - Neutron
          4. Next, navigate to: C:\Users\<username>\AppData\Local\Autodesk\Common
           5. Delete the following folders:
              - Material Library
              - DB Manager
              - Exchange Archives
          6. Next, navigate to: C:\Users\<username>\AppData\Local\Temp
          7. Delete the following folders:
              - 7Z*.*
              - Autodesk
              - ProtoLabs
              - Neutron
          8. Now navigate to C:\Users\<username>\AppData\Roaming\Autodesk
          9. Ensure the following folders have been deleted. If they haven’t, manually delete them.
              - MC3
              - Neutron Platform
              - NINVFUS
              - Synergy
         10. Next navigate to C:\Program Data\Autodesk
         11. Ensure the following folders have been deleted. If they haven’t, manually delete them.
             - FusDoc
             - MC3
             - Neutron
             - NINVFUS
         MAC
           Uninstalling
           Fusion downloaded from Autodesk.com:
          1. Click the Launchpad.
          2. Find and click on the Remove Autodesk Fusion 360 icon. This starts the Uninstaller.
           1. Using Finder navigate to /users/<username>/Library/Application Support/Autodesk/.
           2. Check for and delete the following folders if they exist:
                 - MC3
                 - FusionDoc 2016
                 - Synergy
                 - Neutron
                 - Neutron Platform
                 - NINVFUS
                 - production
                 - Web Services
                 - Webdeploy
           3. Next, in Finder go to the following folders and remove the listed folders/files:
                 - /users/<username>/Library/Application Support/Autodesk/Common - If present, delete the Material Library folder.
                 - /users/<username>/Downloads - If present, delete Fusion 360 Client Downloader.dmg.
                 - /users/<username>/Library/Caches/com.autodesk.senddump
                 - /users/<username>/Library/Logs/autodesk.webdeploy.streamer.log
                 - /users/<username>/Library/Preferences/com.autodesk.AcCoreConsole.plist
                 - /users/<username>/Library/Preferences/com.autodesk.fusion360.Autodesk Fusion 360.plist
                 - /users/<username>/Library/Preferences/com.autodesk.MC3Framework.plist
                 - /users/<username>/Library/CrashReporter/MaterialLibraryMigrator...plist
                 -/Library/Application Support/ - If present and empty delete the Autodesk folder.
           4. Finally, launch a Terminal window.
           5. At the prompt enter open $TMPDIR and press <Enter>.
           6. In the Finder window if present, move the following folders to the Trash:
               - Autodesk
               - Neutron
               - protolabs
           7. Once done, close Finder, then close Terminal.
           8. Next we'll clear the memory of any latent processes. Either restart your system or launch Activity Monitor, look for the
               process "cfprefsd" and force quit it.
           Fusion downloaded from the Apple Store:
           1. Drag the Fusion 360 icon from the LaunchPad to the trash.
           2. Using Finder go to /Users/<username>/Library/Containers.
           3. Delete the entry com.autodesk.mas.
           4. Close Finder.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
We are trying to deploy fusion 360 via Casper. WE are getting inconsistent updates from the App store. Some machines installed the trial version while others installed the full version. We can't use the ap unless it is updated.
Does anyone have experience with Casper ( JAMF) deployment of Fusion 360? In desperate need of help..
Sincerely,
Patti Shayne
licensePRSYA
If this was accurate when it was written, it is no longer. Fusion 360 does not appear in the Windows OS Control Panel.
g-andresen
have a look at the Service Utilities  and try the instructions on how to uninstall it manually.
günther
philpdxthesecond
How are you sure of this? All my Fusion installations are listed in the control panel.
Phil.E
Apologies, I was just logged into the forums on a test account. The reply above is from me.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
