how to turn off all snapping I want to draw free(verticalother constrains)
amxfmx
amxfmx
hello,
how to
I am currently redrawing on a canvas(hand draw sketch) I insert.
I want to make the line function and put my points precisely all along my line(different curve)
but my cursor is attracted to another location to create a constraint as vertical. what I does not want, at the end the lines I create don't fit the original.
TrippyLighting
While drawing the line, hold down the CTRL(Windows) or Command(macOS) key.
That will avoid the snapping.
amxfmx
 thank you very much
perfect that is exactly what hi wanted.
Terribly inconvenient to have to hold a key down when I'm on my drawing pad trying to trace a line from a template and holding that still with one hand with my stylus in the other...  surely there must be a global setting?
chrisplyler
You would think, right?
This doesn't seem to work for rotating an object in Design mode.  I've set rotation snapping to 0.5 degrees, but it keeps snapping within 2 degrees, even with ctrl key.
Thank you
