A SVG file is a Vector format file. In the Screencast I prove that it is. I take the SVG file, created from your original image, and insert it and extrude it. I do not know why you believe it is not a Vector format file? If you want to unlock the sketch and edit it, go to the Browser, edit the sketch, and select what you want to change, unfix it using the Fix sketch constrain command and you are ready to edit to your hearts content.
John Hackney, Retired
