Creating an airplane canopy
co-capt
Observer Observer
Message 1 of 9
co-capt
Observer
Observer
I am trying to create a canopy for the aircraft pictured below.  I have tried everything I can think of, but it doesn't come out right.  I can get the general shape, but I would like to add a little lip in the bottom towards the inside and A tab at the front to go under a lip on the fuselage.  The front doesn't seem to mesh well and there ends up being a hole in the vert front and it looks like the canopy dips inward almost like an elongated dimple
I am trying to print this with a single .4 outer perimeter.
Replies (8)
Message 2 of 9
mango.freund
thanks for the information what you are doing. hmm yeah interesting.
Message 3 of 9
davebYYPCU
Draw the section of the tab on centre line and sweep it around the base of the screen, does not need to be very long.
Might help....
Message 4 of 9
laughingcreek
post your model (export as .f3d to computer, attach at bottom of reply) if you want some specific help.
I'm going to guess that you've lofted to a point profile somewhere causing funky surface quality.
Message 5 of 9
wersy
For this loft you need 2 rails. Maybe something like this?
Message 6 of 9
co-capt
Observer
Observer
This is about as far as I can get.  not sure if I should loft it as a solid, or what planes to loft from and to.  The canopy turned out ok, but it hangs over the airplanes and the front and back come to too sharp of a point.
Message 7 of 9
wersy
I would use loft instead of sweep.
Message 8 of 9
mango.freund
Message 9 of 9
wersy
I changed the design so that the canopy halves are tangentially connected.
