How to pick an axis
How to pick an axis
Message 1 of 10
How to pick an axis
How do I pick an axis (for example for rotation)?
The question seems to be too simple to be explained online.
Ok, I didn't watch all the videos (yet).
And manuals .. that was last century.
Thanks for hints.
Replies (9)
Message 2 of 10
etfrench
Click on it...
ETFrench
Message 3 of 10
SaeedHamza
If you mean the axis is inside of a body or behind it and you can't pick it, then left-click and hold and you'll see a dropdown menu showing everything selectable in that point you clicked at
Regards
Saeed Hamza
Message 4 of 10
If the required operation needs an axis, you can select it by clicking on it
Message 5 of 10
neljoshua
@Anonymous,
You may need to turn the origin visibility on.  Mine is often off.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
Message 6 of 10
Thanx Josh, that was the problem.
Message 7 of 10
I have the exact same problem. Rotated a few objects without thinking about it, and now I spent like half an hour to try and do it again...
I don't know how to click the axis. I tried clicking on the y, z, x axis but this does nothing. Hovering on them says "Pick a rotate axis", but nothing works..
Message 8 of 10
costerjr
Community Visitor
Community Visitor
Message 9 of 10
tomcass240
Having exactly the same problem. It's crazy how hard simple things are just because the user interface is so unintuitive. I clicked to view origin but still I have no idea where I'm supposed to be clicking to rotate a simple object.
Message 10 of 10
etfrench
Click on the object first, not the axis.
 It is usually better to use a joint to position an object (component).
ETFrench
