How do I change the width of line?
I am a Japanese college student. And I use Fusion360 to conduct experimental system.
I have no idea about how to change the width of line when I draft a drawing.
patilsm
Hi @Anonymous,
Thanks for your post and exploring fusion.
Please provide the more details about your workflow. what you trying to Do.
If you created any geometry in modeling work space and used drawing for drafting that and then you are interested to modify the that geometry then
you can modify that geometry by editing the sketch, for that you need to Apply dimension to sketch and edit that dimension the respective changes take place.
("Sketch Dimension" you will find in Sketch ribbon tab, there you have second last option)
those changes also gets updated with drawing.
Please let me know If you need more Help.
Sagar
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
laughingcreek
@patilsm, I suspect he's talking about line weights in the drawing.
Thank you for your reply.
I'm sorry I didn't make it clear enough.
I mean it's the problem of weight of line.
I want to draw a solid line and dashed line, thick line and thin line.
Please tell me how to do that.
thanks
Shintaro
