Fusion 360 Text editing
rtepas
rtepas
Hi, i am using Fusion 360 creating object to 3D print, i am still learning,......
i want to use a custom font to print batches for my car, i have the windows font and that i can use in Fusion 360.
The text can be placed, exploded, extruded, so far so good. I want to have nice and smooth corners, that's where troubles show up.
There is always a part, corner or junction where fillit does not do what i want, messing up the batch.
i thought maybe the way to go is redraw the letters and go from there. So typing the text, create a sketch, redraw en than make a fillet etc etc.
are there any other suggestions to make ?
thanks !
etfrench
This thread may help a little.
This thread shows how to create an stl from a sketch with many short lines and/or splines.  You may be able to use it to create better outlines for your letters.
ETFrench
rtepas
thanks, the options as mentioned in the second method, do not show up in my envoirement, i use the topic to ask further questions. maybe i can find a video with the steps
etfrench
Attach a file (Export and save as Archive (*.f3d)) with several letters in the font at the size you need them to be.  It will be easier to show you this way.
ETFrench
