Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to move and merge faces
8 REPLIES 8
Message 1 of 9
u.ucler
1890 Views, 8 Replies
After spending hours reading and watching tutorials, I've still not figured out how to do it.
It's an iPhone 6S model to be used to create an injection mold for cases. The model is so accurate, that the antenna part has been pushed 0,03 mm down. I don't want to have that detail in the mold, so can you please explain to me, how I move the blue face to be aligned with the grey face? There's a face connecting the two of them, I can delete them but there will be a gap and that's what I'm trying to avoid.
Best regards
8 REPLIES 8
Message 2 of 9
michallach81
in reply to: u.ucler
It depends how that gap was made, either you can offset that face by using Press/Pull command or by Move command (pick move face in Move command dialog window).
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 3 of 9
u.ucler
in reply to: michallach81
I'm getting errors when I'm trying both methods.
I bought the model on Grabcad and used the step file
Message 4 of 9
PhilProcarioJr
@u.ucler
In the model workspace just select the faces you want moved and hit the delete key, the model should auto heal and give the results you want. This auto heal doesn't work in the patch workspace and requires the model to be a solid.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 5 of 9
u.ucler
in reply to: PhilProcarioJr
@PhilProcarioJr It's not autohealing and if I try to use the move tool, it gives me an error "can't handle sheet"
Screencast will be displayed here after you click Post.
54981fb5-3d52-4491-a174-987679215ce6
Message 6 of 9
michallach81
Both ways mine and Phils should work. My guess is that you don't understand what we refer to. To help you we need that model.
Michał Lach
Designer
co-author
Message 7 of 9
u.ucler
You're right, it's definitely me who makes a mistake. You're more than welcome to have a look at the file, if you wouldn't mind 🙂
Here's a link for the file https://a360.co/2tmYZXn
Message 8 of 9
michallach81
File in attachments
Michał Lach
Designer
co-author
Message 9 of 9
u.ucler
In the meanwhile, I managed to fix it myself and I honestly, can't explain how I did it for other people having the same issues. But thank you very much for your help. Very kind of you to fix it up for me. Much appreciated!
Technology Administrators
