After spending hours reading and watching tutorials, I've still not figured out how to do it.
It's an iPhone 6S model to be used to create an injection mold for cases. The model is so accurate, that the antenna part has been pushed 0,03 mm down. I don't want to have that detail in the mold, so can you please explain to me, how I move the blue face to be aligned with the grey face? There's a face connecting the two of them, I can delete them but there will be a gap and that's what I'm trying to avoid.
Best regards
Solved by michallach81. Go to Solution.
It depends how that gap was made, either you can offset that face by using Press/Pull command or by Move command (pick move face in Move command dialog window).
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
I'm getting errors when I'm trying both methods.
I bought the model on Grabcad and used the step file
In the model workspace just select the faces you want moved and hit the delete key, the model should auto heal and give the results you want. This auto heal doesn't work in the patch workspace and requires the model to be a solid.
Phil Procario Jr.
Owner, Laser & CNC Creations
@PhilProcarioJr It's not autohealing and if I try to use the move tool, it gives me an error "can't handle sheet"
54981fb5-3d52-4491-a174-987679215ce6
Both ways mine and Phils should work. My guess is that you don't understand what we refer to. To help you we need that model.
Michał Lach
Designer
co-author
You're right, it's definitely me who makes a mistake. You're more than welcome to have a look at the file, if you wouldn't mind 🙂
Here's a link for the file https://a360.co/2tmYZXn
File in attachments
Michał Lach
Designer
co-author
In the meanwhile, I managed to fix it myself and I honestly, can't explain how I did it for other people having the same issues. But thank you very much for your help. Very kind of you to fix it up for me. Much appreciated!
