How to model stiffness of a linear guide/block for FEA
manusha19802
Observer Observer
manusha19802
Observer
Observer
Hello
I am designing a machine that uses several linear guides/blocks. The data sheet of the linear guide manufacturer has given the stiffness value of bearings. How do I incorporate this value in fusion360 so it can be used in stiffness calculations of the whole machine using FEA?
P
John_Holtz
Autodesk Support
Autodesk Support
Hi @manusha19802 . Welcome to the Fusion forum.
Fusion simulation does not have any method for entering the known stiffness of components. Unless you can simulate the stiffness by modeling a "block" that gives the same stiffness, my suggestion would be to use Autodesk Inventor Nastran which has much more capabilities (such as springs where you can enter the known stiffness).
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
