How to make curved lines on 3d model
mike_vos
mike_vos
I need to make a curved pocket in a 3d model. Anybody that can help me how to make this?
Thanks in advance
Mike Vos
TheCADWhisperer
@mike_vos
If this were my design, I would start by adding geometry constraints and dimensions in the sketch.
TrippyLighting
I wonder how you created the sketch in that design. Did you import that from a dxf, or svg file?
The sketches are not properly dimensioned and under constrained. I'd fix that before proceeding.
The screencast shows one way to accomplish what you are asking for:
johnsonshiue
Hi! The big rounded face on the imported body has a G0 edge. It does not seem reasonable. I have recreated it using a fillet with the same radius. Then I used Emboss command and Full Round Fillet to create the groove easily. Please take a look.
Many thanks!
Software Test Engineer
mike_vos
Thanks ! i will try these options. I did import this as a DXF from the customer.
g-andresen
another solution
günther
