How to make a joint on my camshafts
1 REPLY 1
goagoagoaq
200 Views, 1 Reply
goagoagoaq
I'm trying to design a basic camshaft to develop my knowledge about using joints in Fusion360.
Here is what I'm trying to accomplish
I can't find a way to use a joint to visualize the behavior of my valve.
I've had some partially interesting results using the "tangent relationship" but after rotating my (grounded) shaft the valve is loosing its position.
1 REPLY 1
jhackney1972
in reply to: goagoagoaq
jhackney1972
You are missing a slider joint on the imagined valve rod and you also need to add a round end to it to effectively use the Tangent Relationship.  Model attached.
Edit: If you look at the model closely, you will see I used a sketch point to place the Slider Joint.
John Hackney, Retired
