Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to make a joint on my camshafts
1 REPLY 1
goagoagoaq
159 Views, 1 Reply
I'm trying to design a basic camshaft to develop my knowledge about using joints in Fusion360.
Here is what I'm trying to accomplish
I can't find a way to use a joint to visualize the behavior of my valve.
I've had some partially interesting results using the "tangent relationship" but after rotating my (grounded) shaft the valve is loosing its position.
1 REPLY 1
jhackney1972
in reply to: goagoagoaq
You are missing a slider joint on the imagined valve rod and you also need to add a round end to it to effectively use the Tangent Relationship.  Model attached.
Edit: If you look at the model closely, you will see I used a sketch point to place the Slider Joint.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
