How to import and open a scanned gasket at the correct size
dchannon
Message 1 of 26
dchannon
Every time I scan a gasket for tracing round, it imports at the wrong size, is there a correct way to do this. so it the correct size in fusion 360??
Replies (25)
Message 2 of 26
g-andresen
To retain the dimensions, mesh files should be inserted into the current work space using Insert > Insert mesh instead of File > Open.
Günther
Message 3 of 26
dchannon
And is a JPEG the best file to scan??
Message 4 of 26
laughingcreek
you have to calibrate your canvas after inserting it.
Message 5 of 26
MRWakefield
Can you confirm this is a 2D image scan rather than a 3D mesh scan?
EDIT: Sorry we cross posted - you've answered my question.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Message 6 of 26
TheCADWhisperer
@dchannon
Attach your “scan” file here (whatever format it is).
Someone here will demonstrate how to run Calibrate.
Message 7 of 26
dchannon
So it doesn't bring it in the correct size you still have to size it?? How.
Message 8 of 26
Warmingup1953
If your scan is from a typical flatbed scanner it should, when inserted as a Canvas be at the correct size ( or very very close at least. If not you can Right click on the Canvas' Icon in the Tree and Calibrate. Have you done this before?
Message 9 of 26
TheCADWhisperer
Calibrate.
Message 10 of 26
dchannon
This is the type of gasket I am trying to insert the correct scan as the scan.
Message 11 of 26
TheCADWhisperer
@dchannon
Do you own calipers or at least a scale for measuring?
Message 12 of 26
Warmingup1953
Ok this may be advantaged by some White Board marker dots on the scanner glass and calibrate those. Some say add a steel rule on the Scanner bed...I use dots!img008_jpg.jpg
Message 13 of 26
dchannon
I own callipers
Message 14 of 26
TrippyLighting
@dchannon wrote:
I own callipers
In that case I would measure the interface geometry that gasket sits on, not the "soft" rubber gasket.
Photocopier and even flat bed scanners also use optical systems and distort geometry to some degree.
Once you have sorted you how to get the imagery into Fusion 360 and calibrated, I would stick to lines and arcs to represent the geometry. Don't uses splines.
Message 15 of 26
TheCADWhisperer
@dchannon wrote:
I own callipers
Can you provide information on a real world diameter of one of the features?
What are you desired units? mm? inches?
Message 16 of 26
dchannon
The small holes are 8.5mm
Message 17 of 26
dchannon
And it looks like you levelled up the gasket how??
Message 18 of 26
dchannon
As you may have guessed by now I'm new to this but learning fast thank you and everyone else for your reply's
Message 19 of 26
Warmingup1953
The CADWhisperer has done a fantastic job there!... You have the option to rotate the Canvas.....
Message 20 of 26
dchannon
Yes I have used that but still struggle to make it 100% level???
