How to get suface of the cylinder
AkusoWang
AkusoWang
Hallo,  I want to use "Line : 25" to get surface of cylinder zo dig hole on the cylinder entity, but it got the tangent plane of cyliner surface.
Thank you!
import adsk.fusion, adsk.cam, random,  math, adsk.core, os, traceback
app = adsk.core.Application.get()
ui = app.userInterface
doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
design = adsk.fusion.Design.cast(app.activeProduct)
rootComp = design.rootComponent
x0 = random.uniform(10, 20)
y0 = random.uniform(20, 10)
L = random.uniform(10, 20)
sketch = rootComp.sketches.add(rootComp.xZConstructionPlane)
center = adsk.core.Point3D.create(x0/2, -y0/2, 0)
circle = sketch.sketchCurves.sketchCircles.addByCenterRadius(center, x0)
prof = sketch.profiles.item(0)
extrudes = rootComp.features.extrudeFeatures
distance_1 = adsk.core.ValueInput.createByReal(L)
extrudeInput = extrudes.createInput(prof, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
extrudeInput.setDistanceExtent(False, adsk.core.ValueInput.createByReal(random.uniform(L, L+5)))
extrude = extrudes.add(extrudeInput)
body_1 =extrude.bodies.item(0)
faces = body_1.faces
selectedFace=[faces.item(0),faces.item(1),faces.item(2)]
for i in range(1,3):
        x1 = random.uniform(-x0, x0)
        y1 = random.uniform(-y0, y0)
        planeInput = rootComp.constructionPlanes.createInput()
        planeInput.setByOffset(selectedFace[i-1], adsk.core.ValueInput.createByReal(0))
        newPlane = rootComp.constructionPlanes.add(planeInput)
        sketch2 = rootComp.sketches.add(newPlane)
        lines = sketch2.sketchCurves.sketchLines
        recLines = lines.addTwoPointRectangle(adsk.core.Point3D.create(x1, y1, 0), adsk.core.Point3D.create(x1/5, y1/5, 0))
        prof:adsk.fusion.Profile = sketch2.profiles.item(0)
        distance_2 = adsk.core.ValueInput.createByReal(3)
        distance_Cut = adsk.core.ValueInput.createByReal(-3)
        extrudeInput = extrudes.addSimple(prof, distance_Cut, adsk.fusion.FeatureOperations.CutFeatureOperation)
aliobidi
Hi ,
just change line "32" to :
planeInput.setByOffset(selectedFace[i], adsk.core.ValueInput.createByReal(0))
AkusoWang
hi, Thank you for your answer. this cant solve the problem.
aliobidi
sorry for that
you can post your problem Here   "API FORUMS"
or wait me to take a deep look later
