How to get negative ordinate dimensions?
Noah_Katz
474 次查看
2 条回复
1 条消息(共 3 条)
Noah_Katz
Obviously necessary for CNC programming.
I searched and only found out how to do it in Inventor, not F360.
0 个赞
475 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
jhackney1972
It is labor intensive but you can edit the ordinate dimension text and add a negative sign.
John Hackney, Retired
0 个赞
3 条消息(共 3 条)
Noah_Katz
Thanks, but seriously?
Seems to me that this is a serious flaw opening the possibility for CNC programming errors even after all of the extra work; what if a drawing has dozens of dimensions and you miss one?
Perhaps AD thinks all CNC programming will come from CAM, but there are plenty of machines out there with conversational programming requiring manual input that are used for less complex parts.
