How to fix a rectangle to midpoint of a line?
877cms
Message 1 of 10
877cms
Seems like this should be quite easy but it has me stumped!  I dimension the rectangle 0.8 from the line, then want to centre it along the line. Tried using midpoint but it says "Failed to resolve. Please try revising dimensions or constraints".
I want to centre even if I change the rectangle size, so thought constraints are a good way to go rather than calculating the dimension...
Where am I going wrong?
Replies (9)
Message 2 of 10
davebYYPCU
Make the mid point of the short line, vertical under the midpoint of the long blue line.
select the Vertical constraint.
Hold shift, hover the mouse near the midpoint, when the snap point is displayed left click to select it.
Go to the other line hover, display, select.
Done.
Message 3 of 10
Marco.Takx
Hi @877cms,
Activate the Coincedent constraint.
Hold down the Shift and select the midpoint and then the line like the video in attachment
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 4 of 10
877cms
Not sure if I explained what I want clearly so apologies!
I want to move the rectangle like the attached below, so it stay 0.9m away from the line but is exactly centred along the top line in effect.
Message 5 of 10
TheCADWhisperer
@877cms
Simply add a Vertical constraint between the midpoints as suggested by @davebYYPCU in original Reply.
Done!
If that is difficult to understand, then -
Add a Construction Line midpoint to midpoint.
Now add a Vertical constraint to the Construction Line...
Message 6 of 10
877cms
Sure, this is an example sketch of exactly what I'm trying to do.
Just want to centre the rectangle along the 200mm line, while keeping the 50mm distance from it.
Message 7 of 10
TheCADWhisperer
@877cms
See Attached...
What I did.
1. Click Vertical constraint
2. Hold Shift Key
3. Click midpoint of first line
4. Click midpoint of second line.
Done!
Message 8 of 10
877cms
Thank you @TheCADWhisperer I misunderstood @davebYYPCU solution, I was letting go of 'Shift' and not selecting the second midpoint. Thanks for pointing me back to that 🙂
It works!
Message 9 of 10
TheCADWhisperer
@877cms
My preferred technique is actually to use the Construction Line.
This gives me a visual reference when I come back a year, a month, a week, heck at my age what I did yesterday when editing geometry.
I use more construction lines now than I did on the drawing board 40 years ago when my instructor would constantly admonish - don't erase your construction lines.
Message 10 of 10
877cms
I write a lot of comments in code for that very reason, so you have a good point there!
Thanks for pointing me back in the right direction 🙂
