How to evenly space multiple objects
ashjunkmail
ashjunkmail
Hello, I'm trying t design a tray to hold Multiple Keyhole Marker pins. I have 10 Marker pins of different sizes, that I would like to space evenly across the width of the tray, so that I can then extrude the bottoms into the tray and cut out the holes so that they can fit in nicely.
I can't figure out how to evenly space these pins however. I tried the Rectangular pattern, with a spacing of 10mm and number of 1, but that does not do anything, if I select more that 1 than it multiplies the bodies
I tried to upload the .F3D file but it is too large, it's 100 mb and the upload limit is capped at 79mb. So I uploaded a picture instead.
g-andresen
1. Create a pattern of position points on the base plate.
2. Convert existing bodies into components.
3. Connect the individual components to the base plate at the desired depth.
4. Create the cutouts using the “Combine” (keep tool body) command.
(view in My Videos)
günther
ashjunkmail
Thank you Gunther, I quickly tried that but it failed to cut out the objects when I did the combine feature but I'll try again tonight, thank you for the insight.
TheCADWhisperer
@ashjunkmail
Something isn’t right, this geometry should not result in a large file.
Start from scratch and attach the file here at each step before the file size gets large.
pkomatlapalli
Hi @ashjunkmail,
Did the suggestions from g-andresen and TheCADWhisperer help resolve your issue?
If so, please consider marking the reply that helped as the Accepted Solution. Doing so makes it easier for other community members to find answers to similar questions.
If the issue is still unresolved, please provide an update, and the community will be happy to continue assisting you.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Pavan Kumar
