How to draw and revolve around an angled face
I am trying to engrave numbers and dial lines on a chamfered bolt head. I can draw the lines and numbers, but cant put them on the face at the right angle so that they are of even depth. How would I do this?
etfrench
Extrude|To Object would be the easiest.
That should be Extrude|From Object, then set the distance.
ETFrench
etfrench
The text in the above method will be slightly distorted, but probably won't be noticeable at this small size.  If you need more accurate text then use this method:
ETFrench
