Create form hides the bodies
Hi there. I am a new Fusion 360 learner and I encountered an "issue" following the tutorial here:
https://f360ap.autodesk.com/courses/introduction-to-3d-modeling/lessons/lesson-14-insert-edges-sculp...
At the point I am I have the 2 bodies, like before the minute 1:50. Then I need to bridge them, but..
To enter that "Workspace" I have to select "Create form", the problem is doing so it hides the 2 bodies. I can still edit them one at a time going back in the timeline, but since they are two differents parts of the timeline I can't edit them together. So I am really stuck on what is the problem and how I could bridge them.
Thanks.
jeff_strater
You can create more than one body in each Form feature.  If you want to create a bridge from one body to another, create them both in the same Form feature.
Jeff Strater
Engineering Director
Hi there.
So, there isn't any way to make a bridge between the ones I made? Should I really do everything from the start?
mavigogun
Heh! -you're gonna slap yourself in the forehead :
Copy and Paste, dude- Copy and Paste.
Hi there. This side is so weird so I had a bad time findign again my topic, and I still don't know where I can see the topics I made and replied to.
By the way, how am I supposed to copy and paste in Fusion?
