how to draw a spiral
Message 1 of 18
i cant seem to find the way to draw a spiral in a sketch... is there a way?
Replies (17)
Message 2 of 18
PhilProcarioJr
@Anonymous
Look at this thread is this what you want?
https://forums.autodesk.com/t5/design-validate-document/is-there-a-way-to-create-a-helix-spline-in-fusion-360/m-p/5893904#M37294
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 3 of 18
i dont understand how this would be relevant.. can a helix be a spiral? as i know a spiral, it is constantly increasing/decreasing the radius (of the vertual circle at a certain point on the spiral)...
Message 4 of 18
with spiral i mean spirale...
Message 5 of 18
The steps will be the same as in @PhilProcarioJr 's link, but to create an increasing/decreasing diameter, you will need to adjust the "Angle" setting when you create the coil.
Message 6 of 18
PhilProcarioJr
Message 7 of 18
HughesTooling
Just in case you hadden't noticed coil has an option to make a Spiral.
After creating the solid spiral you can extract the seam using project in a sketch.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 8 of 18
yes, i noticed now... works if you just want a spiral without the need to move it aroud (rotate for exemple) or edit the pitch... since once you deleted the body just to have the projected sketch, editing brings back the original position and even the body as well.
Message 9 of 18
PhilProcarioJr
@Anonymous
There is no spiral sketch tool, as far as I know this is the only work around there is.
Phil Procario Jr.
Message 10 of 18
donsmac
Inkscape has a spiral tool where you can adjust the parameters of the spiral. Save it out as an .svg file and import it into Fusion.
Here's a screenshot inside inscape:
Message 11 of 18
RandyKopf
Thanks that is a great tip!!!
Randy Kopf
http://desktopartisan.blogspot.com/
If my post is helpful, press the LIKE Button If it resolves your issue, press Accept as Solution! Have a great day!
Message 12 of 18
Hate to revive this topic from the dead but when I insert the svg it's unextrudable... I can't select the sketch. What do I need to do to extrude it?Screen Shot 2017-12-20 at 9.32.28 PM.png
Message 13 of 18
davebYYPCU
Presume you want a spiral wall -
in Patch you can extrude the line/s, but Modelling requires a closed profile,
Can tell which one from the pic.
Message 14 of 18
Yes thank you!
Message 15 of 18
martinfry111
Great tips on spirals especially using inkscape. To extrude a scroll, create a thin offset of the spiral and then close the ends.
Message 16 of 18
HughesTooling
@martinfry111 You can also extrude the sketch in the patch workspace as a surface then thicken. Thicken has the advantage of a symmetric offset if the spiral sketch is the centre line.
Mark
Mark Hughes
Message 17 of 18
francoisfournier
Community Visitor
Community Visitor
You can draw the spiral with Inkscape.
Then import the .svg into Fusion.
Then Thin Extrude the sketch.
Hope it can help.
Message 18 of 18
francoisfournier
Community Visitor
Community Visitor
Hope it can help.
