Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to display the coordinates of the curser position
7 REPLIES 7
Message 1 of 8
5642 Views, 7 Replies
How do One display the curser position coordinates when trying to position, e.g., setting a point relative to the orgin or to another or the last point?
Tags (1)
7 REPLIES 7
Message 2 of 8
jeff_strater
There is currently no way to do this in Fusion today.  The Idea Station item for this is absolute-coordinates-amp-grid-level-guides.  Please vote on it!
Jeff
Jeff Strater
Engineering Director
Message 3 of 8
Are you F'ing kidding me!!!!
Message 4 of 8
jtellier466
Ya, this was asked about 2 years ago.... is there STILL no way to see where the cursor is? It should be a no-brainer to implement this! You're already presenting a 2D view (Top, Left, etc) of the object body you're trying to edit/create.  Positioning placement of new objects relative to that should NOT be as haphazard as trying to using the grid markings (which are often out of view).  And having to go back and edit a body position afterwards is VERY annoying and inefficient!  Please tell me this has been addressed since this post was originated!
Message 5 of 8
jhackney1972
in reply to: jtellier466
The retrieval of coordinates of a point or vertex, in relation to the origin is easy.  The video will show you how.
John Hackney, Retired
Message 6 of 8
kennethnhicks
Yea, unbelievable... yea, can find cords after made... the point is to prevent having too!
Message 7 of 8
ray.jenson
The issue is (as someone who used AutoCAD for nearly 30 years) that there should be a means of showing coordinates so that you don't have to continually guess BEFORE placement. It's a massive time saver and it really is MISSING.
Seeing the coordinates after the fact still requires a lot of guesswork, which anyone who is trying to put together something that requires a bit of precision will not be satisfied with, regarding the lacking feature.
Knowing it after the fact is okay, but not having it before the fact defeats the purpose of getting it right quickly.
I'm thankful I don't have to rush anything on my own end of things these days, but really the issue itself is highly annoying, to the point I just want to go off and use a different 3D modelling system (Blender, for example, which does have the ability to display X/Y/Z coordinates on the fly).
That being said, the limitation is not merely costing Autodesk business, it's costing Autodesk users (even free ones) time best spent on other tasks, and is, therefore, a significant limitation.
So... come on, coders! It's not that difficult to implement!
Message 8 of 8
…the purpose of getting it right quickly.
That being said, the limitation… …and is, therefore, a significant limitation.
@ray.jenson
Not a limitation - completely unnecessary.
I am fast, I am precise. I use parametric dimensions.
