Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to design a lubrication groove
3 REPLIES 3
jambrozy
293 Views, 3 Replies
I need to draw a lubrication groove, i paste drawing design what i've got below with fusion design what i draw. Can anyone help with this? Thank you very much in advance for any help.
Labels (1)
3 REPLIES 3
MRWakefield
in reply to: jambrozy
You need to create an angled plane for the groove section profile then create a revolve cut. Take a look at the attached model to see how I did it.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
___________________________________________________________________________________________________________
I've created a Windows application for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
jambrozy
Holy ****, amazing ... I never drawing something like this, thank you ! 🙂
davebYYPCU
Yep, Plane on Angle - X Axis, - minus 30 degrees.  Put a sketch on it.
Then Project > Project curved wall.  Path is actually a circle, coincident to the Projected arc.
Pipe > Cut on the circle.
Might help....
Technology Administrators
