How to create rounded edge?
marek2M3E8
Message 1 of 10
marek2M3E8
This is a problem for me in general quite often. If I have a more complex shape, typically with points, I can't use fillet or chamfer on it regardless of the settings I try for them. Now I need to round the edges of a letter with a circle and again at 0.4mm I encounter an error ( the circle has a diameter of 155m and the extrude of the shape is 4mm. ). How can I make rounded edges even for such a shape?
Replies (9)
Message 2 of 10
TheCADWhisperer
@marek2M3E8
Create high quality geometry yourself rather than use imported poor quality svg.
Message 3 of 10
marek2M3E8
Thanks for your reply. Unfortunately, this is not an SVG, but a modeling directly in Fusion - sketch + circle + text -> extrude. As I mentioned, I have this problem quite often when the edges form a sharp corner or are short. Sometimes I manage to create a bevel by leaving out part of the arc, but that's not what I would have imagined. But maybe I'm just doing something wrong...
I am attaching the export file.
Message 4 of 10
TheCADWhisperer
@marek2M3E8
I would model the text.
Message 5 of 10
bpetersen9BTH4
Fusion highlights the area that is giving the alarm in red.
in this case you have a small triangle sticking out the top right side.
zoom in and youll see a red line on 1 side of the extra triangle. delete this triangle and youll be fine.
Message 6 of 10
TheCADWhisperer
@bpetersen9BTH4
Can you post example>
Message 7 of 10
bpetersen9BTH4
here ya go
Message 8 of 10
SaeedHamza
The issue is simply this small sharp corner here, remove it by selecting both sides of the sharp corner then delete them, that would create a "Delete Face" feature in the timeline, then fillet using the top face will work just fine.
Find attached the .f3d file with the above fix applied.
Saeed Hamza
Message 9 of 10
bpetersen9BTH4
thanks for the echo
Message 10 of 10
SaeedHamza
Not echoing for the sake of it, I was backing up the point because it’s the right one
Saeed Hamza
