How to create a a cut away after I had created a box
Message 1 of 9
I had created a box using these commands
1) Create  ---> Box   ---> Specified all three dimensions
2) Modify ---> Shell  ---> Specified the wall dimension (0.125 inch thick) or 1/8 inch thick
3) On step 3 how do I create a cut away where the cut away is the midpoint between the
    the top corner and the bottom corner ?
    The cut away dimension is 0.50 inch long and 0.25 inch deep.
The picture below illustrates my description.
Replies (8)
Message 2 of 9
SaeedHamza
Just create a sketch on the upper thin surface as the sketch plane
and you'll see a mid point snap to sketch from, then create a center point rectangle with the dimensions you desire
Regards
Saeed Hamza
Message 3 of 9
Hi SaeedHamza. I am a newbie with Fusion 360.
Unless you gave me the exact command then I am at a loss.
An exact command in sequence of order would be like this:
1) Create ---> Box  ---> Specify all 3 dimensions
2) Modify Shell ---> Specify the wall dimension.
Message 4 of 9
dieselguy65
he gave you the command.
you create a sketch on the top edge, or even on the side of the box. which ever you prefer.
draw a rectangle , dimension it.
then use Press/pull to cut it from the box.
Message 5 of 9
etfrench
Message 6 of 9
dieselguy65
give me a minute. i will upload a scfreencast.
this is basic 101 stuff.
have you viewed any of the sample videos? done any of the training tutorials?
Message 7 of 9
dieselguy65
two easy ways of doing it. there are many more.
input your dimensions. i didnt recall them exactly while doing it.
Fusion is running slow right now, as i am doing a backup and swap to a SSD while doing this.
Message 8 of 9
Thank you everybody for your help and especially dieselguy65 for your wonderful video.
Message 9 of 9
TrippyLighting
I’d have to say that before you add another thread that has to do with the creation of what is essentially a cube, do yourselves and us the favor and please go through all of video tutorials in the learning section.
