I have the HOLE dialog box up and selected "placement - from sketch" I selected four point from the sketch at is under the body and the HOLE dialog to the right of "Face/Point" says "4 selected" I have the diameters and depth selected, I'm making a counter sink hole.
But here is the problem: There are no "objects to cut" listed at the bottom. And there is an error showing saying t"There is no target body to cut or intersect."
If I go back to "placement" and select the single hole icon and click at a random location on the body then I do get the current visible body auto selected.
The trouble is that I do not want a hole in a random location. I want the hole(s) at a location defined by construction lines in the sketch
I took a screen cast so you can see.
