How to Create a bottom thickness using a shell command
The shell command allowed me to specify the wall thickness of a cube. However, it does not allowed me
to specify how deep in inches should it cut into a cube. The inserted picture will display what I am trying to do.
SaeedHamza
This is how the shell command works, it gives the same thickness to all remaining faces
If you want to change one of the faces thickness, then just use a presspull command to adjust it as you like
Regards
Saeed Hamza
Hi SaeedHamza. You said "use a presspull command to adjust it as you like"
Please give the exact command like Modify ---> Shell or Create ---> Cube.
For the presspull command is that the exact name and is it under the Modify  command ?
SaeedHamza
Yes, it is
When you select the presspull command, it will change to one-of-three commands according to your selection
If you select an edge, it's a Fillet command
If you select a face, it's an Offset faces command
If you select a sketch profile, it's an Extrude command
Saeed Hamza
dieselguy65
please go do the tutorials.
I wish i had seen this, before the other post
lichtzeichenanlage
Not sure if I'm doing something wrong or my defaults (automatic) are wrong, but it looks like that a shelled body is treated by "Modify Existing Feature" and not by "New Offstet". I know, I can change this with a click, but it might confuse beginners like me 😉
