How to Copy from a Projection (without Losing Link)
jhawkinsRXEMB
jhawkinsRXEMB
I've projected some geometry into a drawing. But for some reason it can't be selected for copying.
Imagine for example, a rectangle projected into a new drawing from existing geometry. And I want a copy of that projection 100mm to the left and rotate it 90 degrees. How can I achieve that, such that if the source rectangle geometry made longer, that change will show in the copy in the drawing?
Thanks.
jeff_strater
You should be able to copy/paste sketch geometry - I just tried it, and it seemed to work OK.  However, that copy will NOT be associative (there is no associative copy/paste in Fusion sketch).  You might be able to get away with a sketch pattern, which should be associative to some level, but there is only rectangular or circular patterns, and you want both a translation and a rotation.
Jeff Strater
Engineering Director
jhawkinsRXEMB
So, you can use "move/copy" to copy projected geometry? For me, "move/copy" works fine for everything except that. If I have projected geometry selected when I choose "move/copy", it deselects. And either way, clicks on projected geometry are ignored when I am in the move/copy tool.
jeff_strater
Yes, it works for me.  You have to select the curves (not the profile), but yes, I can copy/paste it:
(view in My Videos)
Jeff Strater
jeff_strater
oh, interesting.  I just noticed that you specifically referred to the the Move/Copy command - I used just generic copy/paste.  You are correct - the Move command does not allow projected geometry to be selected (probably because it cannot be moved, which was the original intent of this command - copy came later).  This is a bug, I agree
Jeff Strater
davebYYPCU
Dimension the destination sketch articles with the same dimensions as the source articles.  Can use parameters, or just the same dimension reference.
Might help….
