Still very green with F360 and I'm attempting to model a linear bearing. I'm having problems using the push/pull technique on 2 ends of a model. Maybe I need to be thinking about mirroring the model instead?
I have half the model correct but am uncertain of the technique needed to copy/move the sketch to the opposite end for the push/pull technique hopefully I'm explaining that correctly. The image should help with my problem.
Any help would be appreciated.
Adam,
Solved by jeff_strater. Go to Solution.
@Anonymous,
A few comments to your questions:
If you want to share your model, I can show you how this will all work.
Jeff
Thanks for the model link. Below is a screencast showing a couple of ways to do what I think you want to do. I apologize - my comments about press/pull were inaccurate for your model, assuming what you want to do is to copy the last extrude to the other side. The screencast shows a couple of techniques, depending on what you want to do - mirror the whole existing body, or just the last cut feature. One of these should work for you:
Jeff
Extremely helpful.
I successfully mirrored the bearing originally as a solution but was intrigued by the copy sketch concept.
Many thanks for the assistance.
Adam,
I was unaware that I could extrude the sketch without having to move the sketch first...
You video was perfect!
Thanks again.
