How to change the green dot (orbit origin) when rotating using Shift + Mouse touch on MacOS + MagicMouse?
ovisopa
ovisopa
Hello everyone,
I'm going crazy with this design, please tell me how can I change the green dot (origin of rotation/orbit) when rotating the design view using SHIFT + Magic Mouse touch, on Mac OS ?
On windows I remember it was tripple click in the middle wheel of the mouse, but I don;t know how to do it on mac 😞
i googled for how to change the orbit origin, but the suggested menu option is not availbale to me, I tried right click in while in sketch mode, and also while not in sketch mode .... "To change the orbit origin (pivot point) in Fusion 360 on macOS, right-click anywhere off the design in the Design workspace and select "Set Orbit Center".Then, click on the desired point on the model where you want the orbit to center."
Here's a video:
Thank you.
johnsonshiue
Hi! Go to Preferences -> General -> uncheck "Enable camera pivot."
Many thanks!
Software Test Engineer
ovisopa
Thank you. Yesterday it worked for a few seconds after unchecking that option, but after a few more it started to rotate in an annoying way, but today it seems it works properly 😄
