Message 1 of 11
Using a parameter in a dimension
Sometimes, when I use a parameter name as a dimension, the parameter is "live," i.e. changing it in the parameters table changes the dimension. For example, I make a parameter called "length" and use the word "length" as the dimension for some sketch line. Changing the "length" parameter in the table will, in fact, change the length of the line.
But other times, Fusion seems to take the *current* value of that parameter, and that's all. Changing the "length" parameter in the table *will do nothing.*
Is this a known bug? Is there a workaround?
