How to change the default project?
karl
Message 1 of 65
karl
Fusion 360 always opens pointing to the first project I created and will never use again.  Is there a way to change the default project to something else, like the project I'm actually working on?
Replies (64)
Message 21 of 65
8thrule
It was previously defaulting to the most recent, now it defaults to an ancient project.
It's an annoyance.
TD
Message 22 of 65
charliedrums
Has this been resolved or anybody found how to fix it? Every time I open F360 it opens on an old project folder it is extremely annoying.
Message 23 of 65
sasikanth.kollipara
Hi, Thanks for using Fusion.
Currently, it doesn't work that way. You can click on "My Recent data' to view the files that you recently worked.
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Sasi
Sasikanth Kollipara
Product owner and customer support in Fusion
LinkedIn
Message 24 of 65
So it will always default to the first project you ever did from now on?
It did not used to be this way. It literally makes me roll my eyes every single time it happens. I figure it could be fixed with all these people annoyed with it.
Can you please fix this?
Message 25 of 65
JASeiffert
That isn't a useful answer.
It never used to do this like the other person that replied to your message stated.
So how does Fusion 360 decide where it's going to go to? It can't be a random thing so even setting it hard coded to Home or Favorites would be better than the first project I ever did in Fusion 360 3 to 4 years ago.
As complicated as Fusion 360 is as far as programming goes this should be a simple fix.
Jeffery
Message 26 of 65
TripleMikes
What a garbage response. Just accept the non-solution...
Message 27 of 65
-Nick-
+1 Tedious seeing as my first project was rubbish.  Being reminded of it every day is less than awesome.
Message 28 of 65
Max_Marz
Bump, this is still super annoying. Please resolve this super simple issue.
Message 29 of 65
thomasdowler
This is stupid and annoying.
Message 30 of 65
Max_Marz
Message 31 of 65
neil.mendoza
I would also like to know the answer to this! One computer I have Fusion on opens to the most recent project folder I was working on and one opens to the first project I ever made. Would be great if this bug could be fixed.
Message 32 of 65
neil.mendoza
Just had another thought about this so may as well bump this thread in the hopes of some resolution. The bug only shows up for me on Windows, on a Mac it's fine.
Message 33 of 65
Ronthomp
I came here looking for a solution and found none. It occurred to me to archive the offending first project. I then navigated to my current project and closed Fusion. It reopened in the same place I shut down from. Yay!
Ron Thompson
Titusville, FL USA
Message 34 of 65
8thrule
@Ronthomp ,
Brilliant!
Works here (but not on the first try for some reason).
Thanks!
Message 35 of 65
crueby1
Just tried that workaround - it did not work - only difference was that it now opens back at the top of the project tree rather than the first project. Still not opening where it was!!!  Tried multiple times. Still broken.
Message 36 of 65
8thrule
Working here under Windows 8.1.
I leave Fusion closed for a couple minutes before restarting.
Message 37 of 65
crueby1
For me, it never opens in sub-folders of the most recent project, that has never worked. It is an intermittant issue, sometimes it opens in the most recent project like it should, sometimes it opens in the first project. No predicting it, no common behavior/cause that I can see. The workaround of archiving that first project did not change anything other than it sometimes opens at the top of the project tree, not in any project, other times it is in the most recent project. So, that workaround only changed the wrong place it goes! Since it is an intermittant issue, testing it once or twice after a 'workaround' is not enough. Seems like such a simple feature to get fixed, the bug is very annoying. If it matters, I am on Windows 10. And it makes no difference if the restart is minutes, or days later, bug still happens.
Message 38 of 65
leighCB8FK
would like a fix to this also.
Message 39 of 65
Still searching for the answer. I could have sworn F360 used to default to your most recent project. What happened?
Message 40 of 65
etfrench
Just leave Fusion 360 open.  It will cut down on the annoyance🤗
ETFrench
