Text needs apostrophe now?
CNCDude5X
CNCDude5X
when I am sketching text, I notice that if I erase the sample text it also removes the (2) apostrophes and then any text I try to write turns red or does not enter what I wrote?   then I realized I needed to get those (2) apostrophes back in to fix the problem.    I don't remember needing the (2) apostrophes before?
a.laasW8M6T
This is due to the ability to have parametric text now:
https://help.autodesk.com/view/fusion360/ENU/?guid=SKT-CREATE-TEXT
This is new as of the September major update.
note if you want to type some text that contains an apostrophe like CAN'T you need to type an escape character first \ (backslash)
Andrew Laas
Senior Machinist, Scott Automation
