How to assemble two pins?
joergen_nilsson
joergen_nilsson
It seems that it is not possible to use two joints between two components!?
How do I then the best way mount two pins together? See supplemented file.
Marco.Takx
Hi @joergen_nilsson,
I think you are using the wrong type of Joint.
See attachment.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
g-andresen
You just have to ignore the warning when creating the 2nd revolute joint.
günther
joergen_nilsson
ok, thanks
joergen_nilsson
Ok, thanks
davebYYPCU
Set the first Revolve to be 110 degrees offset.  The plate can also still revolve to other angles,
Two joints can be done with the ignore warning, but those 2 joints will lock the assemble solid.
Might help....
TheCADWhisperer
@joergen_nilsson
What is needed is a Point-Line Joint (doesn't exist yet in Fusion 360).
In the real world we cannot manufacture perfect parts.
So in the real world there would also be a bit of twisting in the Revolution Joint.
If Fusion ever adds Dynamic Simulation functionality this condition of avoiding overconstrained Joint conditions becomes a challenging endeavor.
In Autodesk Inventor Professional - Dynamic Simulation Environment this would be accomplished with a Point-Line Joint as the second Joint.  It becomes a quite involved discussion - but the logic is fairly simple.
