Stand alone (non-modal) Parameters Window
robertshomeemail
robertshomeemail
I use parameters a lot and I get frustrated when designing and forget a parameter name or value. My workflow is interrupted any time I need to refer to something in the parameters window. It would be very helpful to have a stand alone (non-modal) parameters window. I can open the window and place it on a different screen and dynamically refer to it while designing.
Marco.Takx
Hi @robertshomeemail,
Make sense.
But for the time being name the parameters with starting with what makes sense to the design.
Box_Width
Box_Height
Box_Wall_Thickness
By typing in box all parameters that are related to box will show up.
But indeed, it's a nice idea to make a parameter box pinned where you directly can edit and see the parameters.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
robertshomeemail
Hi and thanks,
I want to be able to visually inspect the bodies while creating parameters,
renaming parameters, and updating parameter values. This would help me
immensely while creating parametric models. As is, I am forced to open and
close the Parameters window A LOT.
Coming from FreeCAD, their spreadsheet and the ability to tile windows is
something I would like to see in Fusion 360. IMHO, a non-modal Parameters
window would actually provide a superior feature.
Warmingup1953
Would this free add-in work for you?
https://n3rdlab.com/downloads/sheeter/
robertshomeemail
At first glance it seems an ok work-around. However I would prefer to remain inside the Fusion environment if at all possible.
infoTF5PA
I would like the parameters window to be NON-MODAL (remain open) as well. Perhaps if the issue were auto-updating parameters they could add an Apply button (next to the OK button as per professional windows design practices.)
jeffTHXSB
Please add this feature. I've only just started to take advantage of the user parameters -- the constant need to close the window is most annoying. Yes, I do name my parameters very logically. Puzzling as to why this was ever a modal window.
