Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How does one force a "horizontal constraint" on a dimension?
26 REPLIES 26
Message 1 of 27
maula006
765 Views, 26 Replies
So I have the following scenario: A sketch of four wheels.
They have the following characteristic:
  • Wheels can have different heights from the ground (based on an offset)
  • Wheels can have different diameters
  • The placement of each wheel is relative to the first wheel
  • The distance between each wheels is the wheelbase.
So if there comes a scenario where I want to make the middle two wheels smaller and the first/last wheels off the ground a bit, I want the wheelbase between each wheel to remain!
However, what I have currently doesn't maintain any sort of horizontal constraint! So if the wheel sizes are changed... The dimension just "bends over"!
I'm sure there's a solution to this, but I'm not sure how to achieve it.
Do you have any suggested way on how to do this?
Here's a sorta expectation vs reality:
P.S. I'm trying to replicate a "rockered" setup for inline skate wheels using parameters.
26 REPLIES 26
Message 2 of 27
g-andresen
in reply to: maula006
Define a tangential dependence between the wheels and the ground and then the horizontal distances.
günther
Message 3 of 27
TheCADWhisperer
Message 4 of 27
maula006
in reply to: g-andresen
A tangental constraint means that all wheels touch the ground right?
Thing is, in rockered setup (i.e. the second image) only two wheels touch the ground at any given time.
Kinda why this is a bit troubling...
Message 5 of 27
Not all Tangent.
Message 6 of 27
jhackney1972
Sure would have been nice if you had attached your model so the Forum users do not have to build one.  As @g-andresen mentioned, I created a Screencast to prove it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Message 7 of 27
davebYYPCU
During the dimension tool, select items, right click, set horizontal.
Might help....
Message 8 of 27
@jhackney1972
Not tangent to ground.
Message 9 of 27
TheCADWhisperer
@maula006 wrote:
So if there comes a scenario where I want to make the middle two wheels smaller and the first/last wheels off the ground a bit, …
Construction lines.
Message 10 of 27
maula006
in reply to: TheCADWhisperer
Alright. I hope I did it correctly
Message 11 of 27
maula006
in reply to: jhackney1972
Sorry about that! I thought the solution was something simple, so it didn't cross my mind...
You'll be able to see the file when you scroll further down below.
Though I should note that the tangency is not applicable in this situation as it is possible that only some of the wheels may be touching the ground at one time!
It's a "rockered setup" in rollerblades.
Message 12 of 27
maula006
But how do I apply the construction line to the dimension?
Message 13 of 27
maula006
in reply to: davebYYPCU
No can do I'm afraid 😕
Message 14 of 27
davebYYPCU
Not edit dimension,
when creating Dimension, the Menu will have it.
Will check the file, as being a rocking motion, I can see a rabbit hole.
Message 15 of 27
jhackney1972
Something like this, model is attached.
John Hackney
Retired
Message 16 of 27
maula006
I do see how your solution works, but I think that's far too restrictive for my application.
There is no restriction that forces the setup to have rockered setups just the middle wheels touching the ground.
https://skating.thierstein.net/Knowledge/Inline_Skating_Rollerblading_Knowledge_Rockering.html
There exists many rockered configurations besides the normal setup, such as Anti-Rocker (front and rear touch the ground but not the middle) and HiLo (basically skates lean forward).
I understand the idea behind your concept, but unfortunately it won't work for my setup, sorry (at least in a way that's easy to modify via parameters afaik).
Message 17 of 27
davebYYPCU
Edited:
I just read the pictures.
Message 18 of 27
maula006
Ok so... I've tried applying what people have suggested me, and tried the following solution.
I created construction lines connected to the midpoint of the circle that have a vertical constraint, and made a dimension between the appropriate construction lines (the line itself and not the tip).
It seems to respond well to changes in the wheel structures, even extreme ones:
But I have a feeling that this is a stopgap solution more than a permanent solution...
I am really new to Fusion 360 so I'm not sure if this is the best solution to use.
What do you think?
Message 19 of 27
davebYYPCU
White, Blue and Orange articles should keep you awake at night.
Keep them all black.
Tie the orange vertical lines to the artificial ground.
Might help....
Message 20 of 27
maula006
You mean tie the construction lines to the origin?
I made a construction line in the axis origins if that counts... Though, those are orange lines themselves.
What's wrong with construction lines?
