- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I was able to do this earlier, but can't seem to get it to work now. I swear I just selected the mesh/body after clicking on Create Sketch and was able to use Fit Point Spline on the body of the mesh. I also have 3D Sketch ticked, if that's related at all. Now I can't seem to get it to work. The points just keep being added to the grid. What's the correct procedure for doing it? Have I missed a step? I also noticed that if I use a Spline on a mesh, I can only move the points and anchors if I right click and select Move/Copy...? Is that correct? It's a pity you can't move them the same way as with the Line/Spline of a Sketch.
Also, is it possible to add things like the Center Diameter Circle to meshes/solid objects? Or are those only for Sketches?
