How do you scale properly?
t_smith5
t_smith5
Hi
I keep having problems with scaling meshes/bodies. Particularly when trying to scale them inwards/make them smaller. The figure always shows red.
What's the correct why of adjusting them? Is it something that has to be done in the Sketch instead?
Thanks.
davebYYPCU
Model it the right size, scaling is difficult.
Select the face, right click, and select Press Pull to move the face.
If that fails, change the sketch.
Might help....
t_smith5
Okay, thanks for the advice. 🙂
EDIT: To be honest, Press/Pull might as well be renamed Scale as it does do the same thing.
davebYYPCU
In your case, Scale doesn’t / wouldn’t work,
Press Pull did.
Two very different Tools, when you get more experience, you might retract that statement.
Johnc911
Push pull is actually more similar (or identical to) offset face.
