How did you go from my saying that a sketch can be produced with solid lines in the drawing environment to suggesting that part path creation would be ludicrous? Did I suggest that part path creation was possible or that I'd use this functionality to produce a drawing that I use to do so? No!
My earlier post said that a sketch can now be done in the Drawing tool. You responded with only with a limited "phantom line type (dash dash long) " capability. I suggested that you should go an look again as I could do a sketch in the drawing environment that had solid lines.
For me the ability to quickly produce a 2D dimensioned sketch to take to the shed is a significant step forward, I would not use it do drive a CNC machine or laser cutter, to suggest that I would is insulting. Others like me who have requested this functionality wanted it for quick shop discussions not for precision part manufacture.
So yes the functionality is rudimentary, but it's a start. Hence why I thanked the Fusion 360 team for listening.
A few senior members of this forum can be very condescending at times and this can stop other people from making posts or suggestions through fear of being told their post is "ludicrous", especially when then the senior member has made an assumption.
