Feature Request: Drawing tool to insert flat pattern directly from folded model view
jamieSW32L
jamieSW32L
We often have drawing that show the folded model and flat pattern side by side on the same page. It takes about 15 clicks to go back to the model and add each view of the same part to the drawing page.
Suggestion: when you add a folded model to a drawing page, add a quick way (similar to projected views) to add the flat pattern. This would save a lot of time.
jhackney1972
I believe what you desire is already available.  In the video I explain the process which just takes a few clicks while in the same drawing sheet as the folded model.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
John Hackney, Retired
jamieSW32L
John,
That doesn't work when you have an assembly with multiple components. When you have multiple components, you have to go back to the design workspace and redo it all. It's about 15 clicks.
