How do I print out a sketch?
Message 1 of 256
Hi all,
What's the best way to go about printing out a sketch on a regular inkjet printer to scale?
Replies (255)
Message 2 of 256
innovatenate
Autodesk Support
Autodesk Support
  1. Extrude, patch, or do something to the sketch to make 3D geometry
  2. Create a 2D drawing of this with a 1:1 scale
  3. Print the drawing and make sure that you do not have any "fit" settings that will compromise the scale.
Let me know if this helps!
Nathan Chandler
Principal Specialist
Message 3 of 256
Where is the print button??? I can only find dwg and pdf outputs.
Message 4 of 256
laughingcreek
Nathan-
I'd just like to point out that having to go through such a convoluted process, in order to get something as basic as a sketch out of a program, is ridiculous.
Message 5 of 256
I still don't see the print button, is there one?
Message 6 of 256
laughingcreek
Nope, no print button. You have to export first.  Isn't that dandy?
Message 7 of 256
laughingcreek
Luke- the best way for me is to select the sketch from the browser and export as dxf.  Then open in something else to do the printing.
Message 8 of 256
Hm. Any chance of adding a print feature in the future?
Thanks for the heads up laughingcreek. Trying to keep things Fusion if I can, even if it's a convoluted process. 😛
And yes, I do agree it is very ridiculous. Lots of things about Fusion are ridiculous. But the major items are rock solid. Except for stability... Lol. 🙂
Message 9 of 256
Jon.Dean
If you want your sketch to be to scale, then as mentioned previously you can export to DXF, I agree this is not ideal.
You can Capture the sketch but the downside to this, is that it is not to scale.
I will log the issue with development on your behalf.
Jon.
Jon Dean
Message 10 of 256
Thanks Jon, is there any way for me to file bugs or feature requests through Fusion or Screencast? I don't mean to clutter the forums with lots of little bug reports or feature requests.
Message 11 of 256
OK, I still do not understand what to do with the file once it's exported as a DXF.  Are you saying I have to import the DXF into a 2nd party software just to print a drawing from Fusion?
Message 12 of 256
lrsmithmi
It would also be very nice if the print would include the dimensions, if you add any. So you can take a printout to your manual machining equipment.
Message 13 of 256
I think that would be great, but also a good reason to allow us to import 2d geometry into Drawings.
Message 14 of 256
Jon.Dean
Hi Luke,
Any bugs should be logged by Product Support but for Feature Enhancement you can log your ideas on the Idea Station forum page.
Jon.
Jon Dean
Message 15 of 256
I have tried a couple of 2nd party programs for printing drawings from DXF and each one has quirks and problems.
Why is the print button missing from Fusion?  Will one be added?
Message 16 of 256
Jon.Dean
I have logged the issue with development.
No decision has been made yet.
Jon.
Jon Dean
Message 17 of 256
How can printing not be included?
What good is a drawing if you can't print or plot it to scale?  Jumping through hoops to use a non integrated, second party software just to print is ridiculous.
 It seems like Autodesk is getting too caught up in the whole digital cloud scene, and forgetting about guys who design and machine in a job shop.
Todd
Message 18 of 256
Yep, they are so enamoured with the idea of having a fully cloud based CAD system that they are forgetting who uses CAD... except for the maker community!
Message 19 of 256
promm
The process for printing a drawing is to output as a pdf and then print from the pdf.  To make it to a 1:1 scale make sure the views you create on the drawing are 1:1 and then print to scale from the pdf.  A .dxf file is typically used for cutting 2D parts from sheets of materal.
Mike Prom
Message 20 of 256
Could you recommend a program that will plot  D-size drawings that will work with multiple scale factors?
Todd
