How do I draw an auger
I_K_H_
I_K_H_
I want to draw this auger around a 3/4" round bar, using 3/16"x 1/2" rectangle bar, then flatten it. Is this doable?
jhackney1972
It is easy to create an Auger model but the flattening of the flight that will probably not be possible in Fusion.
John Hackney, Retired
johnsonshiue
Hi! This has been discussed in the past. Here is an example.
https://forums.autodesk.com/t5/fusion-design-validate-document/creating-a-flat-pattern-from-a-3d-aug...
Many thanks!
Software Test Engineer
Warmingup1953
Just a design exercise or will you roll the flat bar? (Might not be possible).Capture.PNG
MichaelT_123
