Point to Point Move doesn't automatically refresh when point is moved
digger2k3
digger2k3
Hi there,
I am wondering if this behaviour is intended:
  1. create a sketch
    1. add a simple point to that sketch
  2. import a component
  3. do a "point to point" move with sourcepoint as any point on the component and the target point is the point in the sketch
  4. object will move properly
  5. change the position of the point in the sketch
  6. object will remain in the position of 4.
    1. is this intended or a bug?
    2. for me the move feature should ALWAYS refresh the position of the object if you move the target point
It would be super nice if someone can tell me a trick or if this "is as it is".
Cheers & thx 🙂
TheCADWhisperer
@digger2k3
In an assembly use Joints to associatively assemble components.
digger2k3
ok I'll try that, but the components/ bodies are not really connected to each other. It's more or likely just to position stuff and "testing around" which position is the best.
I'll give joints a try, but then the move feature with point to point is more or less useless imho, because even if I manually update the position it's a mess when bodies overlapping each other in the viewport (hide bodies, select point, show bodies etc.) ... I think it's not really nice in terms of UX. 😕
TheCADWhisperer
@digger2k3
For the most comprehensive help -
digger2k3
sure 🙂
And I figured out that it's working when I move a body within the same component where the sketch is.
It's not working when I am trying to move a component to a target-point which is located in a sketch of another component.
I've added a parameter "targetPointY" which moves the Z position of the target point.
The "dummy - working" body moves then the value changes, the "dummy - not working" doesn't move.
etfrench
Moves are not parametric, so any change in the file will not update the positions of the moved objects.  Use joints.
ETFrench
digger2k3
ok. I assumed that. Is there any chance to make them parametric? Or is there a specific reason for that? Just for my understanding 😉
