Creating a flat pattern from a 3D auger blade modelled in Fusion 360
jonpendleton57
jonpendleton57
Hi Everyone,
Does anyone know if there is a way to create a flat pattern from a 3D auger blade modelled in Fusion 360. I have found YouTube videos that show this being done in 'Inventor' and 'Solid Works' but zero for 'Fusion 360'.
JP
TheCADWhisperer
I doubt it can be done, but -...
Another option might be to do as a surface body and then Unwrap in MeshMixer.
jonpendleton57
Thank you for your reply. I have seen meshmixer used to unfold a multi
curve plate on YouTube. I will try this solution, thank you. Seems strange
that you can't achieve this in Fusion 360 though.
Jon
etfrench
This paper may hold a clue to solving this puzzle.
ETFrench
MichaelT_123
Hi Mr ETFrench,
It is very interesting article,
although "the clue" seems to be ... beyond Everyday Fusion Mortals.
Related:
https://forums.autodesk.com/t5/fusion-design-validate-document/auger-flight-sections-into-flat-patte...
Regards
MichaelT
MichaelT
