Changes at configuration part number/ name does not propagate into drawing.
johnnyL4KW5
Message 1 of 14
johnnyL4KW5
Created drawings for several configuration inside 1 drawing file.
Update the "name" in the configuration table.
Old part names are still referenced in the drawing files.
Is there a way to get the part name/number to propagate into the drawing?
Replies (13)
Message 2 of 14
deepali.pulate
Hello @johnnyL4KW5 ,
It should get propagated actually, have you tried to save the design file first and then to perform GAL on drawings?
After Get All latest the Config file name will get automatically updated in drawings as well.
I tried on my side and it's working correctly.
Please let me know if you need further help.
Message 3 of 14
johnnyL4KW5
Hi Deepali,
GAL was pressed and updated but no change. Also restarted fusion, clear cache and no result.
What did work was to switch off Fusion for several hours and then re-open the file and magically, it updates.
Happy to schedule a call to show the problem.
Message 4 of 14
deepali.pulate
@johnnyL4KW5
Ohh that sounds strange actually.
is this issue frequently reproducible? or only once?
Message 5 of 14
johnnyL4KW5
Definitely reproducible.
Test procedure:
* Make change in configuration table.
* Save change
* Open drawing
* Update drawing by get all = no change to Part name/number
* Close fusion
* Start fusion
* Then get all - now it will change the part number.
Message 6 of 14
deepali.pulate
Thanks @johnnyL4KW5
For the detailed steps to reproduce, appreciate it.
But on my simple files I am still not able to reproduce this issue, could you please share your data, if you are comfortable to do so? I need to dig in more to understand
Or else it is fine.
Message 7 of 14
deepali.pulate
I would Like to understand the scenario, so can we schedule a call?
Please do let me know which time is comfortable for you.
Thanks!
Message 8 of 14
johnnyL4KW5
Hi, is there someway I can send over the video to you privately?
Message 9 of 14
deepali.pulate
Yes, definitely.
You can DM personally here in the forum itself OR else please send it through Mail.
My mail id : deepali.pulate@autodesk.com
Message 10 of 14
deepali.pulate
I saw your video, and thanks for sharing the same.
Is it the same configuration refereed in the drawings title box as well? if not then we have to double click on it then chose the configurations to reflect in drawings.
So in your case for active configuration as well the names are not getting updated in drawings? Also please check if the same configuration is referred in the drawings title box as well
Please refer to the attached video.
Let me know your thoughts on this.
Message 11 of 14
johnnyL4KW5
Hi Deepali,
Same configuration is referenced in the drawing title box. You can see the cofiguration reference on the parts trees. One other difference between mine and your test case is that I have 1 drawing per configuration present, whereas you only have 1 drawing total.
When I close the Fusion and re-open, the first opening of the drawing will take upto 2 minutes as it appears to try and pull the updates across. My guess is that when any changes are made on the configurations in the design and uploaded, Fusion/server does not see the new updated files and therefore when you click "Get all updates" in the drawings view, it does not propagate across. This would also fit with why it works at the next opening of the drawing file.
bests,
John
Message 12 of 14
deepali.pulate
Thanks @johnnyL4KW5  for the detailed explanation.
Then this seems like a issue to me, will report this to the team.
Reported : FUS-202026
Message 13 of 14
johnnyL4KW5
Thank you.
Message 14 of 14
Pramod.kadam
Hi @johnnyL4KW5 ,
Can you please share your dataset? I would like to see which attributes are added in the title block. You can share data privately on pramod.kadam@autodesk.com
Pramod Kadam
Product Owner
Fusion 360 Drawings
