how do i do dxf splines to polylines?
nocturnalwelding
Message 1 of 29
nocturnalwelding
Hey guys, My laser cutter is asking if i can change splines to polylines? Ive been looking and trying but can't figure it out. I tried to post the dxf but i keep getting a error that the attachment doesn't match the file extention.
thanks.
Replies (28)
Message 2 of 29
etfrench
Dxf files need to be zipped in order to attach to the thread.
Try DXF Spline To Polyline from the app store.
ETFrench
Message 3 of 29
nocturnalwelding
How do you zip?
Message 4 of 29
etfrench
Must be a Mac user 😀  It's compressed file format.
ETFrench
Message 5 of 29
nocturnalwelding
haha definitely not. Just never had to zip anything before.
Message 6 of 29
nocturnalwelding
added the file. can't believe all you do is right click and send to folder. lol
Message 7 of 29
g-andresen
try this
as @etfrench  recommended
günther
Message 8 of 29
nocturnalwelding
trying right now
Message 9 of 29
nocturnalwelding
Can you guys tell me if the app worked on either of the files. Laser guy said it didn't work on version 1. I tried again and made a version 2. Thank you
Message 10 of 29
etfrench
Both files opened fine in my 2d CAD program which also can't handle Fusion 360 splines.  What error is the laser man getting?  Can he take a screenshot of the failure?
ETFrench
Message 11 of 29
nocturnalwelding
he's using solidworks and says it has facets or nodes and the laser cutter will stop at each one. Here's a pic of his computer.
Message 12 of 29
etfrench
Can you export as step file?  Solidworks can handle that.
ETFrench
Message 13 of 29
nocturnalwelding
Tried that already. He said it won't be smooth curves. Thank you.
Message 14 of 29
nocturnalwelding
I even wrote a plasma program in fusion and posted it out as a dxf to see if it would work, and no go. The cnc program was good, all the cuts where smooth. Wish I had a table big enough, I would cut it myself.
Message 15 of 29
etfrench
Try exporting a dwg file using the original splines.  Solidworks can theoretically import those.
ETFrench
Message 16 of 29
nocturnalwelding
Ok, I'll give it a go and see what he says tomorrow. Thank you.
Message 17 of 29
mango.freund
hi, there is a helpfull app also
https://www.youtube.com/watch?v=ji64aYVEK7c&t=97s
lg mango
Message 18 of 29
nocturnalwelding
Ok, the dwg didn't work. He recommends tracing over it or importing into autocad and exporting out with polylines cconverted. Here's a email from him with a pic of the error.
See attached it’s the same issue as yesterday. Tell the guys in the forum to open them up or click on the lines there all segmented. I can cut it like this if you like. If you want clean arcs then it will need to be modified. To show that. what you see in this image is what you will get.
Message 19 of 29
nocturnalwelding
I ran dxf to polysplines again.It's kinda wierd in the fact that it will run forever if you let it, but as soon as you hit ok then it stops running. Just makes me wonder if it actually converted it. I let it go for 2hrs.
Message 20 of 29
nocturnalwelding
Just checked with my buddy who has solidworks and you can see all the nodes.
