Then with these two pics, you should get past the road block,
You will be on this screen when you open the file, one sketch with a circle in it. See at the end of the top menus toolbox area, there is a missing Icon called Stop Sketch. At this position you are not editing your sketch, and you can change the circle. Click and Drag the centre point, the whole circle will move. Click and drag the curve, and the radius / diameter will change size.
Click and highlight the circle to be brighter blue, then Right Click menu, has Edit Sketch in the menu. Select Edit Sketch in the Menu and you get this....
Notice the new top menu Item, and the Sketch Palette in this window with Sketch tab in the top line, Here you are editing the sketch, and the Dimension tool is under Create, or press D, or left click the Dimension tool on the Tool box I have it ticked, but you may not have it in the toolbox, so use the Press D key.
Click on the Circle, drag out and place the Dimension and enter a value with the keyboard.
Might help,
