How do I change the dimensions of a circle?
cjshull
Message 1 of 40
cjshull
I know it sounds like a stupid simple question, but I can't figure this out.  I've made a complex cylinder, and realized I need to adjust it diameter later in the process.  I rolled back the history to the circle sketch I started with, and I just want to change it's diameter.  How do you do it?
Replies (39)
Message 2 of 40
anandjoshi
Just drag anywhere on circumference of a circle and it will update. If you wish to be precise, use sketch dimensions to enter specific value.
Its not that complex 🙂
Hope this helps.
Anand
Message 3 of 40
HughesTooling
Right click on the circle and select edit sketch or right click the sketch in the timeline or browser and select edit sketch, then if the circle is dimension already double click the dimension and edit. If there's no dimension you could drag to size or add a dimension. By the way there's no need to roll the timeline back, selecting edit sketch will automatically roll back to the sketch.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 40
jlv11
Observer
Observer
Today is the fist day I am using F360.  I can pull the circle to a new size but I can't get the exact size.  Is there some type of "properties" pane that I could enter the new size?
John
Message 5 of 40
davebYYPCU
If you can drag the circle to a new size, then
Create a Dimension for it, press d on the keyboard, click on the circle, a box pops up, With a blue number in it, that's what size it is now, overtype and put the size in there that you want, press enter to confirm, will jump to correct size and you have to change that number from now on to change size, by then clicking on the number, for the box to come back.
Message 6 of 40
HughesTooling
@jlv11 Take a look through the tutorials in the learning link below.
http://help.autodesk.com/view/fusion360/ENU/
Mark
Mark Hughes
Message 7 of 40
Roman_Vesely
Hi jlv11,
 you can use parameters for all dimensions if you have Design History enabled (which is by default for all documents).
Here you can create new user parameter(s)
new parameter "c_dia" in this case you can use as a parameter for dimension:
Anytime later you can change the value of the user parameter and your circle will recalculated.
Regards
 Roman
Roman Vesely
Inventor - Principal QA Engineer
Message 8 of 40
I could not get any of these approaches to changing the diameter of a circle sketch to work.
Message 9 of 40
davebYYPCU
we will need more information than that,
My earlier post has the technique, only thing I left out was - but you need to be editing the actual sketch the circle is in.
Might help...
Message 10 of 40
JDMather
File>Export and then Attach your *. f3d file here.
Message 11 of 40
kevinmarshall
Just in case someone else does the same as I did. Check you have the right 'Selection Priority' turned on. Select>Selection Filters>Select All. No wonder I couldn't select the dimension 🙂
Message 12 of 40
None of this is working for me. I cannot change the circle diameter. Any help would be appreciated.
Message 13 of 40
TheCADWhisperer
File>Export and then Attach your *.f3d file here and end all doubt.
Message 14 of 40
chrisplyler
Watch this Screencast video showing how easy this is. If your model/sketch is different than this simple cylinder, then you're going to need to SHOW us what is not working. We would like to help you, but you have to help us help you. Either put some pictures up, put a video up, attach your file so we can take a look at it, or at the very least describe in detail exactly what you have to work with, what you're doing, and what fails.
Message 15 of 40
Thanks for your assistance. I am new to Fusion 360 and am frustrated.
My problem may be related to these "ghost" steps on the timeline.
What am I doing wrong to cause this?
Mike.
Message 16 of 40
chrisplyler
Did you mean to attach something to your post? If so, you'll have to come to the web-based forum to do it. Attachments on email replies get stripped out.
Message 17 of 40
Looks, like you have to initially show dimensions when creating the circle to be able to go back and edit it. I am also having the same circle resizing issue after ending the sketch. This is rather frustrating.
Message 18 of 40
TheCADWhisperer
@Anonymous wrote:
...This is rather frustrating.
Dimensions are automatically hidden after exiting sketch environment to clear up clutter.
You have two choices:
1. Right click select Edit on the sketch - your dimensions will now be visible again.
2. Right click select Show Dimensions on the sketch - your dimensions will now be visible again.
I think this is covered in one of the Tutorials.
Message 19 of 40
HughesTooling
They have now added the ability to hide dimensions while in sketch mode to add to the 2 options above. Of course it would be easier to help people if they uploaded pictures of what they're seeing. Show dimensions is not available if you right click the sketch in the timeline, would be very useful if it was.
Mark
Mark Hughes
Message 20 of 40
I see no "edit sketch" option when I right click on the circle. I see a "sketch" option. When I click it, ther is no "edit" option. Please advise.
