How do I add this patern to my planter (probably newbie question)
vanwolleghempiet
vanwolleghempiet
Dear community
I did some research on this extensive forum and found this:
Solved: How do you draw a finned planter like this in Fusion 360? - Autodesk Community - Fusion 360
My result:
However, the patern I'm looking for to design looks more like this:
As you can see my patern has 2 directions. Can anyone point me in the right direction?
Thanks a lot!
aliobidi
Hi ,
take a look at the file below and see how I did it on the time line
and tell me if you have a question
jhackney1972
@aliobidi, You need to check if you attached the correct file.  Looks like you have got you Untitled.f3d files mixed up.
John Hackney, Retired
aliobidi
oh I am sorry and thank you for attention
this is the file
vanwolleghempiet
Hi @aliobidi, can you elaborate a bit what you're doing in sketch 4?
It looks very promising and I already altered your design to what I want but I want to understand it a bit more.
aliobidi
in sketch 4 ..I use  project tool as you see it in the Pic
and in sketch 5 .. I project sketch 4 lines to surface this tool called  "  project to surface" as you see in the Pic
vanwolleghempiet
@aliobidi thanks for this insight. Didn't know this feature but it solves my issue and I'll experiment a bit.
Thanks a lot for your help.
