how can i move an edge ?
maoz57125712
1,189 次查看
16 条回复
1 条消息(共 17 条)
maoz57125712
i have a box and i want to connect the appear edge with the lower one,how can I do it?
0 个赞
1,190 次查看
16 条回复
回复 (16)
2 条消息(共 17 条)
g-andresen
please show a screenshot and share the file
File > export > save as f3d on local drive  > attach it to the next post
günther
0 个赞
3 条消息(共 17 条)
maoz57125712
its a simple box
0 个赞
4 条消息(共 17 条)
davebYYPCU
Simple box has 12 edges, which one do you want me to move?
0 个赞
5 条消息(共 17 条)
maoz57125712
i want to connect the middle edges
0 个赞
6 条消息(共 17 条)
davebYYPCU
Oh no, more than one, at the same time, or one at a time?
0 个赞
7 条消息(共 17 条)
g-andresen
günther
0 个赞
8 条消息(共 17 条)
maoz57125712
I want to grab the higher line and pull it to the lower one
0 个赞
9 条消息(共 17 条)
TheCADWhisperer
Can you hand sketch out your true Design Intent?
Can you post an image of something similar that already exists in the real world?
0 个赞
10 条消息(共 17 条)
davebYYPCU
That’s better now there is just 4 on top and 4 on the bottom to choose from.  Don’t have to worry about which side ones to disappear.
Extrude a.triangle.
Might help......
11 条消息(共 17 条)
jhackney1972
Sort of a strange request but I did a video to demonstrate what I think you are describing.
John Hackney, Retired
12 条消息(共 17 条)
g-andresen
How should the body look after this process?
like this?
günther
13 条消息(共 17 条)
TrippyLighting
Yes, and No. the OP clearly isn't aware of what he's asking and that this is only a "strange request" if we consider traditional  CAD workflows.
In a mesh modeler, for example this is not only not a problem, it is a very common workflow to merge edges and vertices. This is also a common modeling technique when working with T-Splines.
0 个赞
14 条消息(共 17 条)
jhackney1972
Just going on the fact he showed a solid modeled cube, no mention of T-Splines or Meshes, if so, I would have stayed away from the question entirely.
0 个赞
15 条消息(共 17 条)
TrippyLighting
I don't think the OP is aware that working with solid models requires different workflows then modeling with meshes.
That is with "traditional" CAD workflows. There are tools being developed that throw a lot of the "stuffy traditional" workflows overboard and re-imagine modeling with NURBS 😉
I can send you a PM with a couple of links if you're interested.
16 条消息(共 17 条)
maoz57125712
Yes, this is exactly what I wanted, I want to know how to do it so that I can apply this technique to design in the future, I apologize if it was not so clear
I would be very happy if you could show me how you did it?
17 条消息(共 17 条)
jhackney1972
In the video I am using two unconstrained sketches to allow you to adjust the box by dragging any sketch line or point you desire.  I did apply horizontal and vertical constrains to the two sketches to maintain squareness.  You can remove these if you wish to drag the shape into something that does not have square edges.
I will say, using unconstrained sketches in this manner is not a normal practice in solid modeling but if it is what you want, I will not argue.  The model I used in the video is attached.
